Rich_p
Finding The Ecu To Use
Rich_p
I have a 93 309 Gti, when we changed the cambelt it appears to have an earlier engine in it aswe had to use the earlier type tensioner and water pump.
The car does not have a cat either.
When I got the car it had a superchipped 1.6 ecu in it which I changed for a 1.9 superchipped version as that was available at the time.
I want to put a standard ecu back in but am worried there might be different versions of ECU's for earlier/later and cat -non cat cars.
I can't use service box as it's not the original lump in there.
How can I find out what ECU I should be using?
Edited by Rich_p
If its a 1.9 you'd need a 1.9 Jetronic ECU, I think only the Auto engines had the lower power Motronic equipped engine in them, though it obviously depends a lot on which wiring loom and set of components it has on there, sounds like Jetronic if it ran on a 1.6 ecu though.
Rich_p
Is there a different Jetronic ecu for cat/non cat cars though?
It's the code on the front I really need please
cat cars don't use jetronic.
Tesstuff
All UK Gentry 1.9i with Cat use Jetronic.
never knew there was a 309 gentry?
given as mentioned that it ran fine on a 1.6 ecu I'd go with a 1.9 ecu from a normal 128 bhp engine, 0 280 000 359
Edited by welshpug
Rich_p
a couple of the lads on the 309 forum have checked theirs and their ecu codes end in 349?
Did the ecu code differ between a 205 & 309?
Nope. And it's 359, rather than 349. :)
Dont think so, Peugeot's part number didn't (1920 81)
rallysteve
205 GTi 1.6 litre 83-85 Bosch LE Jetronic 0 280 000 321 (1920 43)
205 CTi/GTi 1.6 litre 87-90 Bosch LE Jetronic 0 280 000 333 (1920 59)
205 GTi 1.6 litre 87-90 Bosch LE Jetronic 0 280 000 340 (1920 60)
205 GTi 1.9 litre 87-90 Bosch LE Jetronic 0 280 000 359 (1920 81)
205 GTi 1.9 litre Cat 87-90 Bosch LE/LU2 Jetronic 0 280 000 345 (1920 67)
205 GTi 1.9 litre 8 Valve 87-90 Bosch Motronic 1.3 0 261 200 160 (1929 14)
I have most of the common ones of these spare if you need one, PM me.
Hope this helps :)
Steve
Edited by rallysteve
Rich_p
Thanks for that list. Turns out the 1.9 superchips ecu I purchased is actually a phase 1 1.6 ecu! Best I get a genuine one on there & set it all up again! It might explain why it doesn't feel right!
probably a good idea to check the AFM part number and the injector colour, and the Dizzy part numbers, give it the best fighting chance!
Rich_p
The afm I know is ok as I checked the number previousy. Injetctors are yellow iirc.
I'll have to find the correct dizzy code and check that. The car was a bit of a missmatch when I got it, it even had a be 1 box that had a be3 clutch arm and no reverse cable set up so you could select reverse by mistake when pulling away!
