madspikes
Ms Closed Loop Idle Strange-ness
madspikes
Anyone ideas what is causing the oscillation on the idle valve! - red trace bottom plot
and the settings...
Got me stumped!
Mad :)
Not sure, but it appears to correlate with movements in Graph 3. Is that the throttle position?
I ended up using a frequency of 30Hz, just above the making it rattle at 25-27Hz. Use the lowest frequency you can without it rattling.
The minimum duty cycle for 1000 rpm was 42%.
[L'e$kro]
Hi Peter,
It looks like "Spark angle" is the one you're talking about. I guess it's ignition advance?
@Madspikes
Maybe you enabled an Idle control based on ignition advance as well as your mechanical ICV?
Nicolas
Edited by [L'e$kro]
madspikes
The pink trace you talk about in plot 3 is the spark angle. I have got a fixed angle of 8degree set, when the system goes into idle. So is happening in the plot, is that the idle valve snaps open fully and starts to look at the spark map, then slowly closes and once the idle mode criteria is meet the spark angle is fixed to 8 degrees. Once the idle valve is fully closed it snaps open again...
Blooody odd.
Not sure what is causing the ecu to make the valve open like this.
Mad.
Does the ICV work correctly in open-loop?
madspikes
Yep works correctly in open loop.
Something getting upset and making the valve open fully, in one go, and not stepping it open. Steps close as expected!
Mad
