cammson 0 Posted January 17, 2010 Just a question about changing brakes, i have an old 306 xsi which was given to me for spares for another car. What it does have on it tho is Drilled/Grooved/Vented Discs and brand new pads. was wondering if it is possible just to change these discs pads and also the calipers straight onto my 205? Any info would be appreciated? Cheers, Stuart. Share this post Link to post Share on other sites
j_turnell 134 3 Cars Posted January 17, 2010 I would imagine that would be the 266mm setup, so if you are running 1.9 hubs then the disks and calipers bolt straight on Share this post Link to post Share on other sites
cammson 0 Posted January 18, 2010 cheers bud... will try get at em sometime this week so will update as i learn... Share this post Link to post Share on other sites
shalmaneser 26 Posted January 19, 2010 cheers bud... will try get at em sometime this week so will update as i learn... bear in mind you will need longer hoses too, otherwise it all gets a bit sketchy at full lock (MOT fail too). Don't know if the 306 ones are long enough? Miles does some excellent (longer) braided replacements. Share this post Link to post Share on other sites
C_W 3 1 Cars Posted January 19, 2010 I think for the 266mm brakes you'll be fine with the standard hoses, it's only 9mm different. Share this post Link to post Share on other sites
