hcmini1989
Roll Cage Fitting Advice
hcmini1989
right im in the middle of fiiting a roll cage only the back half .just wondering about the mounting plats ive ordered some steel plates cut to the right size .
now do i cut the floor out and weld the peice in or do i just weld it over the floor
allso are the bolts supposed to run right the way through the floor to outside the car or should i weld nuts onto the plate .ive done a search and seen a few people with the captive nuts on the plates
so wich is the best way .its a track car not going to be doing any events .
marksorrento205
It may help to say if its an omp or SD cage etc as they are mounted / fitted different :rolleyes:
hcmini1989
sd cage its sits flush on the floor .so it should use plates not box section if that helps
http://forum.205gtidrivers.com/lofiversion...php/t86169.html
same as the one at the bottom of the page ^^
but the front cage mounts are alittle diffrent
Edited by hcmini1989
Liquid_106
Captive nuts welded to the underside of the plates and then drill holes in the car big enough to allow the nuts through and the plate to sit flat against the floor.
hcmini1989
ok thats what i thought cheers
If you bought a proper fitting kit it'd have the nuts welded to the plates already;
