Guest teclis103
Mi16 Head Onto A 1600 8v Engine? Can It Be Done?
Guest teclis103
ive got a 1.6 8v rally engine, thats done one season. was looking for a bit more power, but need to stay 1600, so was wondering if its possible to Retro Fit an Mi16 head and some twin webbers? 45's?
Only thing im unsure about is what timing belt, what exhaust manifold, and what about the top engine mount?
Anybody who has an Mi16 head/carbs/manifold and wants rid, im your man :wacko:
evo rich
why don't you fit a 106/saxo 1.6 16v engine 125 bhp standard and with a good exhaust and air filter 140 bhp. cams and throttle bodies 180 bhp
Guest teclis103
cause my bottom end has had alot of work done to it. Race crank, sump baffle, shot peened rods etc. would like to keep that bottom end if possible
it has been done a few times, here's one engine build documented on here that I know of; http://forum.205gtidrivers.com/index.php?s...t=0&start=0
you need custom pistons and a 1.9 MI16 block as the 16v mounting bracket doesn't fit the 8v engine properly, the rest of the bottom end can stay 1.6, you can't use the 8 valve mounting as its in the way of the timing belt and tensioners.
timing belt you'd use an Mi16 one, exhaust manifold you'd be best off using something from Maniflow or the like to get the best out of it.
I don't recall and can't think off the top of my head exactly why, but I seem to remember to do this requires custom rods and/or pistons for some reason.
Guest teclis103
custom pistons doesnt sound very fun :/
miamichris
Or cheap! :wacko:
yep, as I mentioned, you need custom piston at the very least.
there's nothing off the shelf with 4 valve cutouts that'll give a particularly high compression ratio and fit the rods, what does fit the rods wont have any valve cutouts or a tall enough compression height, if I was looking at a race or rally build I'd start with something like an Mi16 piston template and have the design altered to suit.
decoc182
Could you not use xu7jp4 pistons?
harryskid
Sorry to jump in did the 106 conversion refer to the head or engine change?.
Harryskid :unsure:
no, they do fit the condrods (infact they use the same conrod, same partr number and all) but due to using the same height block and a longer stroke crank they are much shorter in their compression height.
Harryskid :unsure:
complete engine, as far as I know the TU5J4 weighs about the same if not more than an alloy 1.6 XU, and if you take them to a reasonable power level (or even standard 1.6 16v) you will need to convert to a BE gearbox as the MA will not last long at all for rallying.
stick to the XU engine and you can use pretty much a stock BE gearbox.
Kev-G
Mi pistons would fit the bore + have the necessary cut-outs....Use custom rods to get to the right compression.
Or custom pistons to fit the 1.6 rods.
Best overall to buy a complete Mi engine with a knocking crank (should be an easy find!!)
Cameron
Is it possible to fit 1.6 internals to an Mi16 engine? I.e. fit the crank, pistons, rods, liners etc?
Yes, but you'd still face the same issues...
Edited by Baz
Cameron
What issues? Aren't the blocks the same height?
Yes, but the internals are essentially the same in 8v's (ie. piston to rod fixing, rod to crank etc) so you'll have the same issues if you were doing it either way, regardless of a 1.9 or a 1.6, Mi block or an 8v block... Not that you can easily use an 8v block anyway due to the mounting issues.
Essentially yes then, you can use the rods and crank, but still need to do something with the pistons!
But that's not the point, the OP wants to keep his existig bottom end too!
black lad
i have seen "renault 17" Mi conversion racing, and its quick but you have to ring the neck out of it, seems the power band is all at the top end of the rev range? its a nice car and has changed hands since, and recently was for up for sale again
I did wonder as I hadnt heard anything about it since then, there was a short video of it on his Bebo page.
I think its a characteristic of any higher powered 1.6 that most of the power is at the top of the rev range, depends a lot what cams and to a point what the intake and exhaust setup works like.
alync406
I was talking to the lad who bought it there last Snday.Looking forward to seeing it out. :D
24seven
Any links to current/working videos of this thing? I bet it sounds fantastic!
renault 17
  alync406 said:
I was talking to the lad who bought it there last Snday.Looking forward to seeing it out. ;)
Do you know who bought it, I'd love to see it out myself. I have some nice videos, can i post them here?
afraid not, you'll need to use youtube or photobucket ;)
alync406
Don't really know him was talking to him at the Cavan Autocross (he was a marshell that day),he was looking at my 205 and told me he bought the car.I would say he will be doing the autocross sometime soon,was meant to be on today but was cancelled.
Wesam
yes u can do it i have the 1.6 engine 8v block with mi16 cranck rods and pistons head u have change the oil check from the back to the font
Yes, if you want an engine to run on 91 RON fuel. I think that combo works out at around 9:1.
