foreigner
205 Hubs On 306
foreigner
I realised that if you put 306 hubs on 205 you will got positive camber.
So applying this logic you have to get negative camber on 306 using 205 hubs.
Are they strong enough for 306 / heavier car?
hub carrier itself should be fine, they are the same design as the earlier cars, later 306's had a larger 18mm balljoint pin and a hollow construction, though are not any lighter.
