Guest teclis103
Oil Catch Tank Suggestions
Guest teclis103
Hi guys, im looking for an oil catch tank to go between the oil filler and the inlet track on my 205. Ive found a few universal fitment ones, but wonder if anybody makes a specific 205 gti one?
cheers for the help
James
pugpete1108
have a search mate, there are some posts about them.
i'm pretty sure there is a company who make stainless ones, but cant remember the website.
pete
just found this:
ebay link
Edited by pugpete1108
Stu
I run that exact catch tank on mine fella....
Edited by Stu
Guest teclis103
stu, you couldnt take a picture of how you have piped it up/mounted it could you mate?
Very clean engine bay btw!
Stu
Yeah no probs mate, ill get some pics later on tonight for you, i had to make a bracket to mount it to the inner wing, but other than that it was fairly simple to get it plumbed up. :)
jimbob
i run a very similar catch tank on my GTi
frobes2
Hi Stu could you pm me the same as I'm having probs with my catch tank on my MI with carbs, using a plastic bottle at the mo cable tied in with the breather from the oil filler jammed in the top, doesn't look pretty but quite practical.
Scott..
Stu
Here you go fellas...
The bracket was made just by folding a bit of ally i had knocking around, it was a bit out so i had to pack the one corner B)
Piping is simple enough, just runs one from the top of the filler and cam cover..
I relocated the filler pot to here, just used a bit of bar with to M8 nuts welded onto either end and used the old mounting points on each bit but with the bar inbetween to space it across to clear the carbs. Then got a bit of pipe to run back to the sump and used a bit of heater pipe to extend the other block vent..
Hope this helps! :)
frobes2
Thanks Stu,
Really helpful advice.. I will be there tomorrow changing my catch tank, where abouts did you get yours from..
Scott,
Stu
I *think* it was from that ebay link posted higher up mate, it came from ebay, might not have been that guy but it was that tank and i think a similar amount of money?
