M@tt
Code Readers/scanners < £100
M@tt
I just wondered if anyone has got any recommendations for code readers/scanners for < £100
Ideally something that would be compatible with both
1999 Mk4 Golg 1.6 Petrol
2003 MGZT CDti (Diesel)
cheers
Edited by M@tt
mr_exe
I bought this one, its not the best but its only failed me once when it refused to talk to a KA. Plus it comes with a nice little earner of scanning neigbours and friends car a £10 a go
Scaner thingy
For a Canbus cars you need the U480 model
omega
Scaner thingy
check his feedback before buying!!!!!!!!
mr_exe
And your point is? At the end of the day it arrived in a couple of days and it works perfectly.
I've one of those cheap plug in scanners, TBH I've found it quite limited as to what it can read. I have it now so I suppose I'd try it first, but my local bloke with a few grands worth of Snap On scanners in his van will come out and read the codes for £20 a time, he hasn't failed me yet.
You'll struggle to find anything that'll do both of those for that little cash, It has only been mandatory in the EU since 2003 for Diesels, and Petrols since 2001, unless you're lucky that they do run generic OBDII.
Edited by welshpug
omega
my point is that he has had alot of bad feedback quite recentley
Henry Yorke
Your MG will have the BMW system in in which will be OBDII and they are not that cheap. My brother has a Snap on one that was a few grand which is pretty good, though I took my BMW to Quarry Motors in Sheff and they scanned and diagnosed and reset everything for me but it was £40. You need to reset a lot of things after a fault to clear the ECU so it is generally not the sort of thing you can do at home :ph34r:
woodsy
I have a mac tool small scanner which was 80 quid which just really does the minimum EOBD vehicles. Its ok for a quick check but anything decent i get my new snap on solus pro (carbon fibre look) out.
