rallysteve
Which Manifold For Mi16 In 205
rallysteve
Just planning which manifold to put in my 205 when i put the new engine in. I would like one of the 4-2-1 ones rather than the standard type which i have. The engine will be tilted on grp N mounts. I have looked at the pugracing one, the spoox one and the pugparts ones. They all look very similar but vary greatly in price. Which one is best or should I have one made up by local engineers?
Cheers Steve
which Mi16 is it?
j_turnell
I would un tilt the engine for a start, as thats a bodge imo, no need to tilt the engine. You can get the standard one reangled to clear the bulkhead which is fine, but if you do want a 4 branch then i would speak to Miles (pugracing) as i've only ever heard good things about his manifolds, wouldnt like to comment on anything made by spoox.
rallysteve
Sorry, its a 1.9.
Sorry, thought the engine is referred to as 'tilted' as standard, as far as i understood 'untilting' it was the bodge done by lengthening the bottom mount fork? Anyway, to clarify it will be mounted at the standard angle ;)
Cheers, will have a look into Miles' ones
Steve
They are all the same but I don't add 300% mark up on them,
Pugspares with it's new owner does have another source as well but the design is 99% the same
rallysteve
Cheers guys, have talked to Miles and will now save up for one :)
Steve
