Toddy
Light Valve Springs For A Dummy Build On Xu10j4rs
Toddy
Hi
I want to check clearance I have @ tdc on a GTI6 head, it presently has Catcams single springs in at the moment, I therefore require something with just enough pressure to seat the valve when I refit the head with a used gasket to check the clearance.
TIA
You don't need a valve spring. Just put the valve in without any spring, retainer etc. Sit head on block, gasket etc. with piston at 6 deg after TDC. Then drop valve onto the piston. Use a dial indicator to measure the drop.
Toddy
I hazard a guess that 6 degree after TDC is the point where there is the least clearance?
Rippthrough
If you do want some then LeeSpring are cheap...
The closest point for the inlet can be anywhere from 6-12 deg. depending on stroke, rod length, cam grind etc. There can be >0.010" difference between there and TDC. Enough for a close engine like the XU10J4RS to go bang.
B1ack_Mi16
I always use springs from some old RC cars when mocking up to see how much valve clearance I have.
