davey205
Bulb Gone Behind Heater Control
davey205
one of the bulbs has gone behind the heater control, how do i get at it and what sort of bulb do i need please
miamichris
simple job! hayne's book is your friend for things like this mate, tells you how to remove trim etc in there. Basically all you have to do is pull the heater control knobs and they come off, undo the screws behind there, take off the heater panel and change the bulb.
They're a wee small push fit bulb, you can get them at your motor factors etc :)
miamichris
no problem, I think thats the only screws you have to remove to get at the bulbs but its been a while since I changed one of those bulbs. You'll figure it out anyway as you go, that will get you started/most of the way!
