splant
Sunroofs
splant
i know how they should work but never knew how they work is there a pipe on the engine somewhere that sucks the air out to open it,,then what refills it to seal it?? what goes wrong with them ? cheers
j_turnell
If you remove the scuttle panel you should be able to trace the vaccum hose from the servo, check its all connected and the plastic t-piece isnt snapped off. Will be the thin black rubber tube with a 1 way valve in it.
splant
sorted ,tube was badly kinked as it came through the bulkhead behind the sound deadening .also discovered what the small glass dome was near sunroof handle , think its remote central locking sensor although i have no fob to operate it ..
j_turnell
Correct, all you need to do is find a matching fob and sensor, swap them over and it should work. You could also get the code off your original item and go to pug, but it would cost a lot for a replacement matching fob.
