jesse390
Mi Engine Mount
jesse390
Hello, fitted mi engine today and found i need a top engine mount, is there any other mount from different peugeot marques that fit, Have looked on the forum and ebay to no avail, desprate, any help would be appreciated. Cheers, Max.
309 ones are the same.
If that's what you mean.
jesse390
Yes top mount and alternater mount
I'm now presuming you mean the actual metal mount, bolted to the engine, rather than the rubber bush mountings as i initially thought?
jesse390
Its just finding them now
which bit do you mean by the top mount?
the rubber bit with the studs either end or the arm that goes over to the bracket on the engine?
jesse390
Yes the alloy mount that bolts to the engine. held up by rope at moment
Ahh, this is an Mi16 alloy block alone part, i'm afraid it's not shared with any other model!
jesse390
s*it!!!
You can buy them but there not cheap
Yup, you're better off finding used ones as Pug want around £300 for the pair!
jesse390
Sods law, I thought i had it all sown up, Thanks for the info.
jesse390
Has anyone got one, I cant get on the wanted page.
There's a reason for that!
jesse390
And that is?
Paul_13
You need 30 posts, sorry way it goes and I know it's annoying
jesse390
What is annoying is remembering the bloke i bought the engine off, removing the engine mount and not thinking anything of it. Doh!
jesse390
What about the bx mounts.
BX 16v mounts yes, but that's the same engine anyway. None of the other engines have the same mounts.
jedibusa
I know that feeling as i didn't know they were different either. I waited several weeks for one to appear on ebay and in the end bought the two parts seperately. There were three on ebay the week after.
Sorry this doesn't help much but it is worth checking to see if anyone is breaking a 405 or BX on ebay or other forums. Just had a quick look now and can't see any
Somebody will have one for sale somewhere! Maybe you will be lucky and one of them will read this thread
I believe he's already found some! :ph34r:
jesse390
Like baz said i managed to find some, Cheers, Mate
