Weser
Wiper Arm Help
Weser
I had a bit of a problem in the cold weather, the other morning I was warming up the 205 like normal. I went to pull the wipers off on the windscreen as they were frozen on. Unfortunately the the plastic bit on that holds the wiper to the to the arm was so brittle it snapped off the arm.
I didnt think this would be a problem went and got another wiper blade but none of the fittings fitted my arm! My wiper arm is straight with a small circle bulb at the end. The arms on my diesel have a hook on the end.
So I was wondering if anyone knows if you can get replacements of these plastic connectors on the straight wiper arm? Or is it better just to replace the whole arm with a hooked arm?
Andy
jimbob
I have a wiper arm from a GTi that is now not needed if you want it, its yours for £5 aslong as postage is okay as size is an issue
Weser
Cheers mate but I have some wiper arms around on some scrap cars.
Just wanted to know if you could get the little plastic bit to keep it original?
