Andy F
Aluminium Caps For Cam Ends
Andy F
Hi
Hoping someone can help. I remember a while ago seeing a post where someone had made caps to get over the cam ends of an MI. Since i am not using a dizzy or PAS off the cam i would like to get a pair and was not sure if anyone made them?
not sure who made them, but the 2.0 405 uses a metal cover that bolts on over the exhaust cam end, not sure if it would fit the 1.9 or over the inlet cam too though.
Edited by welshpug
Swazy
not sure who made them, but the 405 uses a metal cover that bolts on over the exhaust cam end, not sure if it would fit over the inlet cam too.
i´m pretty sure it was a member here called blackmi16 if i remember right. I was looking for those caps also, but the oe one for the exhaust cam isn´t available from peugeot, it came from the T16 XU10J4TE out of the 405
Edited by Swazy
not just the T16, was on my N/A 2.0 as it doesn't use a vacuum pump like most S16's, and they use the same head's you are right though it is marked NFP :)
I know someone who can make you these if required.
Martin 'crf450' made them. Or there's some Gutmann ones about if you can find them!
sonofsam
anyone with a turning Lathe and a bit of know how can use it as a spinning Lathe and make some spun end Caps,
Gentrix
I need one aswell, if someone does a few.
Andi
Dj_mini
Iv got a set of the ones martin made brand new drop me a pm if your still after a set as i dont have an mi any more.
tri_longer
If someone is going to volunteer to get these made I'd be interested.
PVFCpug
Same here, need a couple for inlet and exhaust!
Andy F
Have pm'd but still seems there is a market for these
sonofsam
What do they look like?
mr_exe
I'd be interested in one for the exhaust cam
sonofsam
Do they have to have that register on the flange, as I smashed this over in five minutes!
Spinning boys, not machining! :)
