harryskid
Webber Carbs
harryskid
Can any one tell which carb set up is best for a 1900 8 valve 40s or 45s. Also should i expect aprox 10 bhp more.
From Harryskid :lol:
chris-stdt
From Harryskid :)
My 1.9 is on webber 40s and has had alot of work done to the head (fast road cam and port/polish) and the 40s are plenty big enough
As far as power gains im not sure you get much more power ,its more that the power is there right away when you want it.
Oh yes and they sound bloody fantastic :lol::lol:
woo83
My 1.9 was also on 40's the head and cam were pretty much standard. I don't know exactly how much extra bhp they gave but once they were set up it was definatly quicker and I thought smoother too. (louder aswell) :):lol:
hillbilly
I have 45s on mine and it runs fine
harryskid
Thanks for your advice mates. Iam probely going the 45 route as i missed out on the Ebay bid. Harryskid :lol::mellow::unsure::blink::D
frobes2
I have 45 on mine and standard they have the same jets in them..
Definately get them balanced, I agree with all the other comments, they do sound the nuts especially if you got 4 branch manifold and nice exhaust!!
Good Luck and let us know how it goes and what you think.. (noise)
Scott.
harryskid
Scott.
I hope they wont be too noisey as i have to get through noise tests on my rallys.Thanks for the reply Scott.
Harryskid :lol:
skinner2k3
Thanks for your advice mates. Iam probely going the 45 route as i missed out on the Ebay bid. Harryskid :lol::mellow::lol::blink::)
Probably a good idea as a 1900 is going to want 36mm chokes, with a bit of head work you might even need more and then you are out of 40 DCOEs.
I have 40s on mine, I wont be replaceing them but given the choice again I would have gone straight for 45s.
MrG
I have 45's on mine, together with a sorted head and cam etc, certainly goes well. Oh and as has been said above, they sound very nice and quite loud at high revs.
Guest nelly023
I have just picked up some 45's for my 1.9. Do i need to anything with the ignition side or can i run the standard distributor. I've got the manifold, fuel regulator and pump and am hoping that will be enough. Any help or advide would be much appreciated
MrG
mine runs the std distributor and connections etc. All I did was fit the regulator, and the carbs, removed the ECU but left the wiring in place (I haven't a clue what goes where and what they do so chose to leave them in place under the bonnet etc) and that was it.
rescue dude
Harryskid :P
I have 40's and a Magnex exhaust and have never been clocked at more than 89db.
All the noise with carbs is induction and is at the front.
MrG
the highest mine was registered was 92db. But nromally 89db
yippeekayay
if you do have induction noise issues at scrutineering.... drop a cushion under the bonnet or a layer of rubber foam, it worked for mine for years...jsut remember to take it out as soon as you clear srutineering lol
That's not always viable though is it, scrutineering is static, engine off, then i've always been noise tested while queuing for or literally just after the first run at Sprints. Although Autocrossing/Rallying etc is different yes.
Edited by Baz
yippeekayay
yeah i meant for rallying so it wont work.... sorry...
harryskid
Yer they have started to noise test at intervals during the event. Mind you though the last one i did was in oct and this was the first time i've seen this done. It could have been down to fact that the venue had been in dispute with locals and it went to court and the motor club won but with certain restrictions.
Harryskid :lol:
yippeekayay
definitely dont want to get caught doing it then, it wont win you any friends, city working country folk, dont you hate the whingers!!!?
mfield
Not being a member of the spelling gestpo I'm loathed to point it out but in the interests of helping doing any searches you might do it should be handy to note it's " Weber " not " Webber " :)
:) Someone had to!! :lol:
Tesstuff
Not being a member of the spelling gestpo I'm loathed to point it out but in the interests of helping doing any searches you might do it should be handy to note it's " Weber " not " Webber " :D
Fantastically well put, 'in the interests of helping doing any searches' :blush:
thomasrally
From Harryskid :rolleyes:
Don't they reckon the 40's will give you more torque and the 45's a better top end?
Can't say I've tried 45's but my 40's on an aftermarket exhaust manifold has a pretty good torque curve
Swings and roundabouts, considering either 40's or 45's will have similar size chokes it's pretty irrelevant though.
