dino20vt
Thinking Of Getting A Strutbrace
allye
I purchased this from ebay a couple of months ago, it made a slight difference, worth the £27 posted!
Missing half your air filter!
I have the same strut brase (budget one) I can tell you back to back it made a noticable difference. I would recoment it to anyone.
Ali
Cameron
See the problem with those cheapo ones is, they're just designed as engine bay bling, nothing functional. Yeah you've got a nice steel bar to limit movement, but what's it attached to? A pissy little 2mm steel bracket that's going to flex and flop around all over the place!
Look at the ring around the strut, particularly next to the bolt nearest the camera, it's about 15mm wide. I bet you could get a fair amount of flex out of that with just your hands!
Edited by Cameron
tdr_1976
Yes, I did away with the rest of the filter, it's now got a steel mesh filter jubilee clipped onto where the drum was, it's done the job nicely.
Cameron - It works for me.
Guest RESTELL
I brought one from www.strutbracer.co.uk last week for £60 delivered and its perfect. i recommend them.
harryskid
A proper one should be thicker and be adjustable, also be prepared to cut away some of the bonnet ribs for it to fit.
liamd205
Ali
Hi. I have an OMP one on my rally car. Good sturdy job and its adjustable! Wasn't badly priced either. Never had any problems with the bonnet closing. Think they do lower ones as well. Liam
Rupertfinch
I've a new OMP steel upper strut brace and the only difference I can honestly notice (in the extensive 7 miles of testing its had) is that the flipping bonnet doesn't close right anymore. Everything tightened down and torqued well, but still a rise at the back rear of the bonnet that wasnt there before.
1. Is there a right way round for these i.e the adjuster to the left or right of the engine bay? Mine is what I've pereiced to be the correct way round, so that the OMP logo is the right way up.
2. Those with a good fit are you still running with sound deadening under the bonnet?
harryskid
I had to dump the sound deadening and also as i said cut some of the bonnet ribs out. Bonnet now fit perfectly but i might add i do not have a standard bonnet catch. I have comp bonnet pins, so there is a bit more adjustment. I know its a lot of phaffing about but the struts worth having. By the way the sound deadening is apperantly worth money as a new
item is aprox £70.
Harryskid :rolleyes:
mr_exe
We had this problem when fitting an OMP one to a friends GTi, it actually touched the bonnet. The solution in this case was to flatten it to make it less curved, which we did with a forklift truck
liamd205
My OMP had the adjuster just above the coil. But then I was also using comp bonnet pins and the sound deadening was also removed!
Edited by liamd205
harryskid
Lend him your forklift.
Rupertfinch
In the absence of a forkie, I have decided to say balls to the strutbrace! :)
allye
I just have to disagree, it is held on securely with 6 m7 bolts and I have tried to move it about and it is solid. It can't not be offering any support as it a physical attachment between the struts! It tightened my front end. oi oi
m@ttc
so long as they stop those cracks appearing above the rear windows ill fit one. :lol:
do they? :unsure:
pyrrhic
I drive a CTI, which has a lot more flex than a GTI for obvious reasons. My car came with a strut bar fitted. I removed it once to see how it felt, and the difference was noticeable. With the bar on the CTI is sure on the corners and there is very little scuttle shake. With the bar off the front end feels loose and scuttle shake is noticeable. Yes, the bar is functional.
Slo
Another one here, it makes the cti much better on the handling to the point where its overbearing the rear end (since the rear hasn't got one)
and yes its adjustable cant go wrong for the price
Mac Crash
definitely works.... have non-adjustable one fitted (origin unknown, bought from Miles)
as said by others, the 6 little bolts are plenty for a road car which at times is under far more load than a rally car due to the amount of grip from the tyre exiting corners, what produces more load? a sticky tyre on tarmac or a gravel tyre on earth? the strengthening plates are for rally cars taking yumps, not tarmac cars... my view only
what I despair at mostly in topics like these is the amount of folk going on and on about strengthening yet they weld with mig welders.... real men use oxy/accetelane, guess those skills have been lost too... just putting on the fire proof survival suit now :blink:
acox99
Technology has changed. Tig welding is what most people use for building chassis'/space framesthese days. Unless your talking to people who weld alloy bodies in which case a lot gas weld and a lot use tig. It's down to preference. Gas welding steel with steel or brass is still done. Old British bike frames are brazed. Gas welding puts a lot of heat into the material, and you have to know what your doing otherwise it can move all over the place. I'm no professional but I can make a descent job with oxy. But il weld with a mig over gas most days.
Bobbafett
I bought a Sparco one for my 1.9 but it the bonnet doesn't close flush with it on. It'll be in the for sale section at some point!
allanallen
Who's gonna buy it now you've said that???
Bobbafett
Someone who is willing to remove the sound insulation or cut the bonnet? I've read a number of times on here people have Sparco ones fit no problem but maybe i'm unlucky. Or i'll just put it on eBay?
Daviewonder
Helmets with bonnet lifters?
