Guest matarmitage88
Indicator Relay Blowing
Guest matarmitage88
Hi,
The indicators on my 205 keeps stopping, they will work for a short period then just stop, I have changed the rlay, again Ok for a while then stop again.
The hazard warning lights always work though
any ideas?
Its usually the hazard light switch, the indicators are wired through them. Next time the indicators don't work wiggle the hazard switch and if they come back change the switch.
Weser
I have had problems with the hazard switch before so its a good start!
If its not the fault check the fuse box they are known for faults.
