Craig89
Oil Leak, Help Please
Craig89
I have a rallye with a TU3S distributor and it is leaking oil. I first thought it was coming from where the distributor is bolted to the head (failed o-ring seal) so i replaced the o-ring but oil was still coming out. Next i sealed it with silicone but it was still escaping from somewhere? I took the distributor out and have noticed 2 holes on the underside of it, they look like they should be there but dont know what there for and if this is the possible cause of my leak?
Any help would be great.
Thanks, Craig
allye
Not sure if the XS came with a Ducellier ignition, if the came with the bosch dizzy then that doesn't fit the Rallye engine as it doesn't sit quite right on the head. Also make sure its not the rocker gasket as they terrible on these engine!
It will say Ducellier or Bosch on the dizzy, if its Bosch then you need to change it.
Ali
Edited by allye
Craig89
Ali
Alright mate, it is a Ducellier distributor and im pretty sure that it is coming from the dizzy. If you have a Ducellier one then could you see if yours have the 2 holes in it like mine? Because them holes are whats puzzling me.
Cheers, Craig
allye
Will have a look tomorrow, dark now. As you have changed the 0-ring and it still leaks is wierd!
Ali
drmo
I think that some of the tu3s engines had ducelier distributor. And it is not that uncommon that the distributor itself is leaking. Take the cap off and have a look.
Craig89
After having it off and striping it down i think it is just well worn therefore letting out. I think my best bet is to find a replacement. Thanks for the help
rescue dude
Try these dude's.
http://www.h-h-ignitionsolutions.co.uk/
sub205
the distributors use sealants as well, these are often worn out.
try to get a replacement, an exchange dist will only last for some time if the sealents have never been renewed.
