hillbilly
1.9 Brakes
hillbilly
Will 14 inch wheels fit over the 1.9 brake set up?
Depends on the wheel!
James_R
Mostly 1.6 pepperpots (speedline) do as to speedline 2108's loads of room.
Galifrey
Its the SMR's that may not fit I am led to believe.
Are you fitting 1.9 brakes to a 1.6? Broken nipples?
hillbilly
No, i have a 1.4 that i am fitting a 1.9 too.
I have series 2 106 rallye steel wheels and am wondering if i can use the 1.9 brakes to keep my wheels.
cheers, ryan
Galifrey
cheers, ryan
Ah thats clearer, i have no experience of steels so will let an expert answer.
Pretty sure S2 steelies house 1.9 brakes fine yes. :blink:
the original S2 106 brake caliper is quite a bulky ATE one that sits around the same offset and thickness disc as the 1.9 205, they'll house most 266mm brakes so you shouldn't have any major issues with 1.9 205 brakes I would imagine :blink:
James_R
Yes they do Cameron runs them no hassles :)
hillbilly
Ok thanks everyone i will get pics up asap
