davidc
Plating For Bolt In Roll Cage...
davidc
Whats the spec for plating the shell of a car for fitting a bolt in roll cage ?
Im sure it was 100 square centimetres under each foot/mounting point using a minimum of 3mm thick mild steel ???
Does anyone know or have access to the RAC MSA Blue Book or Irish Green book ?
Any help greatly appreciated.
Cheers,
David
Craigb
Cheers,
David
11. Each mounting foot of the front, main and lateral
rollbars must include a reinforcement plate at least the
same thickness as the wall of the tube to which it is
being welded (minimum 3mm). Each mounting foot
must be attached by at least three bolts (minimum M8
ISO grade 8.8) on a steel reinforcement plate at least
3mm thick and of at least 120cm2 area which is welded
to the bodyshell (see Appendix 2, drawings 13 & 18).
Alternatively the mounting feet may be welded direct to
the reinforcement plate. This does not apply to
backstays (see below).
13. Their mountings must be reinforced by plates. Each
backstay should be secured by bolts having a
cumulative section area at least two thirds of that
recommended for each rollbar leg mounting above,
and with identical reinforcement plates of at least
60cm2 area (see Appendix 2, drawing 19)
davidc
Thanks for that....I knew it was something like that.
Just need to get the cage now !!
Cheers,
David
