luke1987
Engine Painting
luke1987
Hi all this might be a stupid question so go easy but am i right in thinking that if i paint the block black the under bonnet temp is going to be higher than if it were silver as black attracts heat? just wondered as if the body is painted white (under the bonnet) it will reflect enginge heat back towards the block which would then absorb the heat sorry if its a daft question but you dont know unless you ask.
Jamal
Why? Iron blocks usually painted black as factory default.
luke1987
It was just a thought thinking of heat dissipation and such just wondering as its an alloy block
Ryan
I can't really see the paint colour making all that much difference to be honest.
Galifrey
Black radiates more heat than silver/white whilst it will absorb more heat as well black, it is the heat source, so the radiant effect will be greater.
happygoron
Doubt it will make much difference but a black engine will make it much harder to spot oil leaks!
luke1987
Thanks for the replies it can stay silver then as was said helps spot oil leaks.
Galifrey
Or build it properly so it doesn't leak :rolleyes:
