megavolt0
Piston Oil Jet In Xu7jp4 Bottom End
megavolt0
Somebody did it? How? I have many ideas, which to choose? Which will be more correct? Can somebody give me advice?
megavolt0
Thanks, but it's variant without valve... :D
Oberon
Turbo diesel oil spray jets, as found in 205 turbo diesels. Don't ask me how to fit them though.
B1ack_Mi16
That said it must be easier and probably better solution just to take a Mi16 block and put the XU7 internals into that?
megavolt0
In Russia instalation of other engine is not easy. It is a lot of problems with documents.
guffe
If your keeping your engine NA just ignore the jets. Only if your going to run on endurance events on track for hours or hundreds of kilometers at Autobahn on full throttle, then MAYBE you could need oil jets.
