GTI6BOY
Rallye Engine Stopped Working?
GTI6BOY
Was driving along when the engine died.
Pulled to the side of the road and tried to turn it over, but it wont fire
Had a little play around and i cant get a spark
I have tried a brand new coil
With the ignition off i have 1 live to the coil, and with ignition on i have 2 lives and the other 2 read 2.0v? I thought i should have 3 lives and an earth?
Any ideas
allye
This is a TU3 not your GTI-6 engined Rallye!?
GTI6BOY
Tu yes
swordfish210
I had this happen once, it turned out that the shaft inside the distributor had snapped so the rotor arm wouldn't turn. The ignition system on the TU engines are pretty simple so it shouldn't be hard to trace the fault.
GTI6BOY
Rotor arm was turning
just been to my local motor factors and purchased a ignition module for £35 and the car fired straight up
B)
Wallby
I also need a new ignition amplifier, but I have 2 choices, 5 or 7 pin. Anybody know which one I need for my Rallye? Otherwise I'll have to go home and check!
GTI6BOY
Yeah 3 pin...lol
Thats thrown a spanner in your works has'nt it?
at a guess (as its the only one I can see listed for a TU 205...)
  Quote
5945 55 MODULE
christopher
My Rallye died in full flight on the motorway once. Revs just droped and it wouldn't start. The only time it ever failed me.
It also turned to to be the ignition module.
If you watch the rev counter (if you have one) then it should flicker when the engine is turned over. If it doesn't then its probably your module
Wallby
I was thinking 3 pin too! All the pictures i have looked at have 3 pins! Ill check in the morning then hopefully the man at unipart can find a 3 pin one for me.
thanks for your help guys
