allye
Rallye Decal Problem!
allye
Hi all,
A while ago I put some new decals on my Rallye, however one of the doors has been sprayed at one point in its life :ph34r: . This was done around the decals so when I took off the originals there was a ridge of paint around edge of the decals. My new new 'Rallye' decals are slightly different size so wont simply go into the ridge outline.
How should I deal with it? :)
One guys suggested sanding it down with really fine wet and dry then t-cutting it, but I'm not so sure!
Thanks a lot, Ali
GeorgeXS
If the new decals are slightly too small then i can see the problem, but if they are too big can you not cut them down to fit the ridgelines??
Sanding is the only other option without a full respray, should be fine if you are careful.
George
GeorgeXS
Double post :)
Edited by GeorgeXS
allye
Double post?
Do other models share the same colour? Bianca white isn't it?
Cheers, Ali
Anteas
Double post?
Cheers, Ali
Theres a white rallye in a scrap yard in bury with its doors still on
and yes other modles did use the same white afaik
allye
I'm having the boot of him and having it sent so will ask how much he is after for the door, also it will add a fair bit to the courier so will look into it.
How much do you think a boot and door will wiegh?
Thanks, Ali
GeorgeXS
Double post?
Posted exactly the same stuff twice.
Silly me :)
jonnygoodhand
Hi all,
A while ago I put some new decals on my Rallye, however one of the doors has been sprayed at one point in its life :( . This was done around the decals so when I took off the originals there was a ridge of paint around edge of the decals. My new new 'Rallye' decals are slightly different size so wont simply go into the ridge outline.
How should I deal with it? :rolleyes:
Thanks a lot, Ali
Did you purchase the decals off me at goodhand.co.uk/pts-decals?
If you let me know the exact size of the decal you removed, I could make one to size.
allye
I got them off ebay, the letters are slightly bigger than the originals, so you could make me up some the exact same size?
Thanks, Ali
jonnygoodhand
Thanks, Ali
Were they from AJ Decals? Always wondered about these...
Are they the Rallye 'Script' decals then? And not the stripes? If so, the most accurate way of tracing them would be to do a rubbing, if possible.
Scan this in at the correct size and forward me the image. I can then trace this and cut the decal from it. I used this method for my XS recently and the result was pretty much dead on.
If interested, drop me a PM.
allye
I don't have scanner! Can you recomend any way of sanding it down and buffing it up/spraying it?
Cheers, Ali
GLPoomobile
Then why not post the rubbing to Jonny and he can do the rest? ;)
allye
I don't have a scanner! Which is a bummer.
GTI6BOY
piece of paper, trace it then send it in the post
jonny is a top bloke who does a top job
allye
Thats a great Idea, will PM him now!
Thanks, Ali
GLPoomobile
Eh? That's what Jonny suggested a few posts back :wacko:
Oh never mind, I'm away to go and bang my head off the living room wall instead..................
Edited by GLPoomobile
Leet205
Eh? That's what Jonny suggested a few posts back :)
Aweseome, Video?
allye
Haha, I was stating posting it was a great idea. I wasn't saying GTI6BOY's suggest of tracing it was a great idea as Jonny had already suggested that!!! Will do it tomorrow though.
Thanks, Ali
