whizzer71
Anyone Seen These Before
whizzer71
Hi guys finally got round to taking some pics of the pistons that I removed from that hiflow turbo creation, they are JE and are 85mm and I removed them from a turbo d block that had been bored to 86mm with a Xu10 turbo petrol head on it.
I know Martyn is hoping to sell them but would be helpfull to know what they are supposed to fit, specially as all XU10 2.0lts are 86mm std ?.
:ph34r:
whizzer71
And finally .....
taylorspug
Can you not contact JE with some of the measurements or a part number and see if they can identify them?
whizzer71
May be worth a go just thought I would try the obvious first .
:ph34r:
They might just be some custom jobbies?
Edited by Baz
jonir
is it the new 2 litres (ew) or something that is 85mm. stock..?
have you measured it??
Issam
85m != 85mm
give me the bore,compression height and distance from the first ring to the crown of the piston and I will give you the specs.
