djinuk
Spec Your Suspension Setup
djinuk
ok, to help my understanding of 205 suspension setups and help me decide where to go with mine i wondered if folks on here would fill out a spec on there car
CAR USE
Engine Type - mi16 etc
Car use - Fast road/ Tarmac track
RIDE HEIGHT - -45MM
FRONT SETUP
Front suspension - Gaz Ghas 250LB springs /eccentric mounts / standard arb
REAR BEAM
Dampers - bilsteion group n
Torsion bars - 23mm
Arb - 25mm
This is just an idea really to get to grips with common setups , what works etc and also i imagine it will be usefull for others.
Car Use; hibernating road car, VERY occasional trackday use
Ride height, Circa -25mm
Front setup - Bilstein B2 Streetline with Ventura Springs.
Rear setup - rebuilt beam with o.e dampers, standard torsion bars, recent upgrade to 22mm ARB but not tested since.
Toddy
Skip Brown Cars (SBC) phase 2 suspension:
Front setup - Bilstein Inserts. 180lb ish springs - Will change to Eibach.
Rear setup - rebuilt beam with Bilstein Group N Tarmac, 20mm torsion bars, 23mm ARB, SBC neg camber Kit increasing overall track by 17mm
going softer on the front toddy?
boombang
Use: none yet, tarmac rally / fast road / track - 10 point cage with stitch welded chassis
Ride height - no idea!
Front - Gaz Golds, 225lb 9" spring, eccentric topmounts, strut brace, 309 Gti ARB, looking to get a 205 ARB to try out
Rear - Newly built beam, Gaz Golds, standard ARB and bars, with 25mm ARB for track. Torsion bars to be ordered very soon, just no idea what size!
Toddy
I have eibach on my daily car and it is ok with 550lb R & 400lb F, Miles and Sandy also champion Eibach so will accept their wisdom and, iirc Sandy mentioned that the spring rate is a rising rate from 80 -205lb so should give a better ride over the potholes which we also know as roads, and also be ok for spirited driving/on track.
andyjstone
CAR USE
Engine Type - GTI6 on TBs
Car use - Tarmac track
RIDE HEIGHT - around -30MM
FRONT SETUP
Front suspension - Bilstein Group N/Eibach springs/BBM Group N rubbers/standard arb
REAR BEAM (soon to be)
Dampers - Bilsteiin Group N
Torsion bars - Standard 309
Arb - 24mm
Group A beam mounts.
Edited by andyjstone
RossD
Car Use: Currently hibernating, but fast road with occasional track day
Engine: 1.6 TU on throttle bodies, 130-150bhp.
(Note, this is a base model not a GTi)
FRONT: Eibach 7001 springs with Bilstein Group N dampers, BBM Group N top mounts. Polybushed GTi wishbones, strut brace, standard 17mm GTi anti roll bar.
REAR: 19mm TB's and ARB (For now) with Bilstein Group N dampers.
185\55x14 tyres on S2 106 Rallye rims.
Edited by RossD
GilesW
CAR USE
Engine Type - mi16 (XU9)
Car use - Tarmac track with occassional road use
RIDE HEIGHT - not sure. But 'sensibly lower' than standard.
FRONT SETUP
Front suspension - Gaz Ghas 275LB springs/ no arb
REAR BEAM
Dampers - Gaz
Torsion bars - 23mm
Arb - 25mm
jengis
CAR USE:
Engine - 2.0 8v, circa 125bhp
Use - road toy (and once on track!)
Ride height +/- 0 (but a little high at the back due to weight loss)
FRONT SETUP:
Bilstein yellow B6 struts with standard GTi springs and top mounts; standard GTi ARB, lower arms etc.
Standard 1.6 GTi bendix brakes
REAR BEAM:
Standard GTi with o/e 306 GTi-6 dampers (probs no different to o/e 205!)
TYRES + WHEELS:
195/50 r15 Hankook Ventus k110 v12 EVO (can't fault them for hard road use and despite melting tread rubber they wore evenly on track)
Tacky aftermarket 15 * 6.5" alloys
NEXT PHASE:
lower by 30mm, Eibach 7001 springs, BBM top mount rubbers, 22mm rear ARB, solid beam mounts.
Edited by jengis
andyjstone
FRONT SETUP:
I thought the B6s were black and it was only the Group Ns that came in yellow?
j_turnell
ENGINE - healthy 1.6 8v on group n mounts
USE - daily driver/fast road
RIDE HEIGHT - -35mm
FRONT SETUP - gti-6 shocks, group n rubbers, ventura springs
REAR BEAM - gti-6 shocks, group n mounts, 22mm arb
TYRES - 185/65/r14 toyo proxy cf1 front - gdyr eagles back.
SOON TO HAVE - 309 rear axle, 306 arms, 24mm arb, 20.5mm torsion bars, -30mm
Edited by j_turnell
jengis
Well, they're yellow struts with blue dust gaitor. The mono-tube inverted spec, but standard length (B8 are the shortened version). Bought under the understanding that they had the code "B6" through Balance Motorsport for about £160 each. "B4" were listed as the black ones (pretty much o/e spec).
I think Bilstein changed their codes/product descriptions a while back, perhaps that explains confusion?
Rippthrough
This could take a while :)
shalmaneser
RIDE HEIGHT - -35mm
306 arms?
BERTMAN
Engine Type - S16
RIDE HEIGHT -35-40MM
FRONT SETUP
Front suspension - Bilstein sprintline dampers and springs
Standard Gti ARB
Group N top mounts
REAR BEAM
Dampers - bilstein sprintline
Torsion bars - standard GTi
Arb - Standard GTi
calvinhorse
so whats this all about?
bigsheep
Track use
Gaz adjustable coilovers / dampers
225 lb springs
40mm drop
Gp N solid rear beam mountings
New OE everything else...
aCe
Some very suprising set ups there!
Won't give mine away :lol:
philfingers
Engine Type - Mi16 with TranX diff
Car use - road rally and odd road use
RIDE HEIGHT std at the front, tarmac spec rear (approx 322mm between centres)
FRONT SETUP
Front suspension - PTS gravel coilovers (currently rebuilding inserts myself.. . .with mixed success),
Standard Gti ARB
PTS Gp A top mounts, Baker BM fully adjustable top mounts with GpA bearing in the bottom drawer. .. ..
309 botton arms, fully adjustable R/J'd setup in the bottom drawer. . . ..
REAR BEAM
Dampers - bilstein gravel
Arb - Standard GTi
Gp A mounts
Rippthrough
FRONT
Gaz coilover casing with custom internals and oil, plus a new outer tube with cranked over end cap for +1 degree extra camber, remote res. added stainless braided hose and a 1.25" expansion chamber, different oil spec, gas charged with a custom floating piston + die spring assist for ride height adjustment, plus twin front springs to reduce resonance and Sandvick 38 steel shimmed damping piston (which is also modified)
Rose jointed, T45 tubular wishbones, fully adjustable type that can be tweaked for castor/camber/anti-dive/rollcentre,
Custom solid top mounts, Aurora PTFE bearings.
Rose jointed (forged aluminium), alloy-bodied droplinks for when I'm running a front arb.
Rose jointed (forged chro-moly), alloy-bodied trackrods + quickrack
Seam welded subframe.
38mm T45 lower brace, carbon fibre/alloy upper brace.
Progressive poly-foam bumpstops.
Height - +20mm from stock (rally/rough track setup)
REAR
Solid aluminium beam mounts.
24mm anti roll bar.
Fox remote reservoir rally-spec dampers with 50lb/inch spring rate assistance + hydraulic bumpstops.
ZX trailing arms for 0mm toe.
1.5* neg. camber.
(+20mm ride height)
Edited by Rippthrough
RossD
Any pictures of your front setup Rippthrough? I think I've seen pics of the individual parts on the forum (?) but not with it all bolted together!
CAR 1
Engine Type - standard 'strong' 1.6 8v
Car use - Everything, Road, track/sealed tarmac, Sprints/broken surfaces etc.
RIDE HEIGHT - -30MM
FRONT SETUP
Front suspension - Koni Sport adjustables with Eibach 7001 springs & BBM GrpN top mount rubbers, 1.9 hubs, 309 wishbones and driveshafts, standard arb.
REAR BEAM
Dampers - Koni Sport
Torsion bars - Standard 205 beam with BBM GpA mounts
Arb - 24mm
ZX Trailing arms
CAR 2
Engine Type - 1.9 Mi16, Throttle bodies & mappable management, PeterT stage1 inlet cam, 4-2-1 PugRacing manifold with 2.5" system, Kaaz plate LSD.
Car use - Fast Road/ Tarmac Track
RIDE HEIGHT - -35MM (Although the rear needs raising a little)
FRONT SETUP
Front suspension - Koni Sport adjustables with Eibach 7001 springs & BBM GrpN top mount rubbers, 1.9 running gear, standard arb.
REAR BEAM
Dampers - Bilstein Tarmac
Arb - standard (or 24 from other car!)
CAR 3
Engine Type - Rebuilt 1.9 Mi16, Mi16x4 cams and management, 1.9 'box with 4.4FDR.
Car use - Tarmac track, Fast Road etc
FRONT SETUP
Front suspension - PTS Bilstein Tarmac Insert Coilovers, 250lb Springs, Eccentric top mounts, 1.9 hubs, 309 wishbones and driveshafts, standard arb.
REAR BEAM
Torsion bars - 309 beam 23mm Torsion bars, BBM GpA mounts.
Arb - 25mm
306 Trailing arms
CAR 4
Engine Type - Rebuilt 1.9 Mi16, inverted Jenvey Throttle bodies on custom long inlet manifold, Emerald K3, PeterT Stage 2 inlet cam, 1.9 'box with 4.4FDR, TranX plate LSD.
Car use - Tarmac track, Broken surfaces, Sprints etc
FRONT SETUP
Front suspension - Leda Emulsified Gas Coilovers, 300lb Springs, Eccentric top mounts, 306 hubs, RJ'd Adjustable wishbones and 309 shafts, No ARB.
REAR BEAM
Dampers - Leda Emulsified Gas
Torsion bars - 309 beam with 25mm Torsion bars, BBM GpA mounts, SBC Negative Camber kit.
Arb - 22, 24, 25 & 27mm - weather/surface dependant.
Yet to decide with the rally car!
kyepan
Engine Type - Mi16 with Quaife ATB
Car use - road, but hopefully some sprinting soon eh Baz! or at least a track day.
RIDE HEIGHT reduced a bit, but not a alot
FRONT SETUP
200lbs springs on gaz coilovers, set at 1/3 stiffness
Top mount strut brace
309 front arms
refreshed top mounts / bearings etc.
REAR BEAM
22mm torsion bars, 24mm arb
gaz dampers set at 1/2 stiffness
zx arms for toe and camber
and the all important loo killing solid beam mounts
Drums FTW
Brakes
307hdi 283mm + ferrodo ds2500 pads
Wheels (heavy propper stoppers)
Citroen C5 steelies (4.6kgs)
comments- grips hard, but not as fun as when it was all wooly and over-steered everywhere.
oli-pug
Engine Type - Gti-6, peter t inlet cam, vts box with tran-x diff
Car use - Road and Trackdays
Ride height - approx -45mm front, -40mm rear
FRONT SETUP-
Gaz Gold coilovers (280lb or 350lb 8" springs)
Eccentric mounts
309 Gti arms with genuine bushes
Std 19mm anti-roll bar
REAR BEAM-
309 gti beam
-1.2 camber
BBM Grp.A mounts
Bilstein tarmac dampers
23mm torsion bars
Anti-roll bars (20mm to 27mm)
7j O.Z Superleggeras fitted up front for track use, to increase track width and give space for 205/50 tyres.
