Robbie G
Adjusting Clutch Biting Point
Robbie G
Just a quicky, which way do I turn the nuts on the clutch cable in order to lower the biting point (make it bite with the pedal nearer the floor)?
Rob_the_Sparky
You need to lengthen the cable.
Robbie G
So turn the nuts anti-clockwise yeah?
Rob_the_Sparky
Yeah
You won't do any harm so play until it feels right but remember to lock them together when you finish - don't want them to fall off...
Rob
Robbie G
Thanks. I was getting major clutch slippage yesterday, partly heat and partly worn clutch probably but need it to last a little longer!
Guest Ricey155
Rob yeah thats correct
id have done the same but mine was at the end of the thread
so new clutch is in £211.50 inc vat fitted
and all done
Rob_the_Sparky
Slackening the cable should make no difference to a slipping clutch as the more you tighten it the more the pedal rises, it doesn't hit and end stop (thus keeping pressure on the clutch) until the pedal is so high it is almost impossible to use...
Rob
