Which Connecting Rods (tie Rod) For The P/s Rack
In my hunt for Part numbers which my local parts man gave me and the online system I can find the following and as ever with Pug not the most helpful choice of
3812.32
3812.38
3812.95
I know I need 2 rod's as I;m converting the Xsara rack to fit the 205, the 309 numbers are different again ;)
Any ideas?
32 and 38
32 and 38 don't come up in servicebox, only 95, which is a bare track rod without the boot or rod end.
Motaquip only list one for the 205, VTR655.
Thats the confusing thing on the system, I'll have to order aa couple of the 95's and the 4066.13 boot
Galifrey
Assume this is for mine mate
:unsure:
Yep, Ordered some today so we'll see what happens
Cameron
Do you really need to swap the rods? There's about 75mm of thread in the ends so I cut 15mm off mine and 15mm off the track rod end. Works perfectly! :ph34r:
Galifrey
Do you really need to swap the rods? There's about 75mm of thread in the ends so I cut 15mm off mine and 15mm off the track rod end. Works perfectly! :D
They cut the old track rod ends to fast remove the rack I believe but hey. 60 quid shipped, can't moan too much.
:ph34r:
Cameron
<_<
Fair enough, what a pain in the arse!
As said the Cut rod end doesn;t look to great and is quite floppy, Other end isn;t too bad but for the cost of the new arm's it's not worth messing around, well we will wait and see
philfingers
my 205 and 309 PAS racks have the same length arms fitted. Not sure if this helps but I have the dimensions somewhere. .. .
