nickaliath
[car_overhaul] Nickaliath's 205 GTI Overhaul
Galifrey
Is there any benefit to removing this pipe between manifold and vacuum pump? I still have it fitted on mine for what it's worth.
Just don't think it is needed, vacuum pump will provide all you need, probably justa fail safe if the pump breaks :rolleyes:
nickaliath
Yeah thats true.
any ideas on this connector??
not sure where this connector goes?
nickaliath
Connected up the battery today but for some reason the battery light on the dash is always lite up and when i turn the key to start it does nothing, you can just here the relays in the glove box click????
Any ideas??? is my wiring all ok???
nickaliath
just looked through the wiring again and have noticed this connection i have done:
yellow/green m444 permenant earth - Green/yellow M ignition amp
Im wondering if this is the problem, im gonna connect m444 direct to earth when i get home to see if that helps!!!
Paul_13
Are your still having problems with the exhuast manifold?
I had to put the manifold roughly in place before putting the engine in, then tighten the bolts while the engine was still hanging.
Was alot easier.
Sorry can't help on the wiring I bought a loom off Spiky
nickaliath
havent done the exhaust manifold yet, but will probably end up pulling the engine forward to get it on.
im determined to do the wiring loom myself, im gonna get the wiring diagram for the gti-6 loom then i should be able to work it out.
I did see something about the rev counter wiring needing alterations for the gti-6 loom?? is that true.
Tilly205
have you got all the oil level and other sensers fitted and the throttle body? and the alternator wiring
could be worth looking to see if its any thing to do with air con ... i have looked at my old 306 but cant seem to find it in the pics maybe check pug306.net as they should know straight away
Edited by Tilly205
nickaliath
havent got the throttle body connected but most other sensors are connected. but it should still turn over shouldnt it???
alternator is all connected, hopefully the right way.
ive got the autodata wiring diagram for the gti-6 engine now so i will have a look through that to check its all correct.
nickaliath
quick update, havent had much chance to do anything on car.
Im hopefully going to get a look at the wiring diagrams tonight. ;)
nickaliath
got round to checking the wiring today!!!! finally!!!
worked out why engine wouldnt turn over!!! i hadnt connected the ignition switch cable to the starter motor!!!! numpty!!!
anyway connected this up and it turns over, although my battery is shot so need to get another before starting up.
cammson
this is a really informative thread, projects coming along well.
I have just completed my 205 project but already have another... its a half converted gti-6 so this thread will come in very handy for me.
keep up the good work!
nickaliath
Yeah will do. And ill post up the exact wiring connections i have made so people dont struggle when doing diy installations.
nickaliath
Got the battery nice and charged on the 205 gti so today went out and had another go turning it over to start.
Got it turning over fine, injectors are pulsing but no fuel pump pressure!!!????
Tested the white fuel pump wire on one of the two multiplug connections, it had only 1.20 Volts through it??? not sure if thats right?? wouldnt have thought so.
Anyway i thought id pull up the hatch in the rear for the fuel pump connection so that i could connect a live straight to the pump.
The connection wasnt even connected?!!! i pressume this is due to the car being carbed before i had it, but still when i connected it nothing!!! i took it out and found that all the electric pump guts where removed!! pain in the arse so now ive got to get a new pump.
BusEngineer
How disappointing!! :angry:
Im sure someone on here can sort you one out to get it running
Get a wanted post up
nickaliath
The fuel pump turned up in the week and was fitted with no problems.
I had a good look over the wiring diagrams and noticed i never gave the loom a permanant live!!!! :lol:
The small live loom that comes off the battery and goes to the starter and the alternator was connected.
On the alternator end i had it connected to the smaller terminal on the alternator.
the alternator also has a connection to each of the two terminals from the engine loom, the larger one being the live wire connected to the lives on the main relay.
so i originally had the battery live on the small wire terminal which was causing the battery light to stay on the dash and would not start.
i took it off the smaller connection on the alternator and connected it to the larger connection to give live to the loom wire.
Finally it started up straight away on the key, hopefully these wires on the alternator are correct.
see pic below.
next step is to get the engine back out, get exhaust fitting correct and then paint the bay. ;)
yeah that's correct, lucky you didn't fry the alternator :lol:
nickaliath
excellent, i thought it must have been ok.
Its funny i thought the alternator started getting warmm without turning engine over :lol: LOL
nickaliath
here is my gti-6 wiring guide that i have compiled. http://forum.205gtidrivers.com/index.php?s...p;#entry1036154
thanks to everyone who has helped me out on my car, which has enabled me to do the wiring guide :).
I will have a complete gti-6 conversion page on www.peugeot-205.co.uk as soon as its all done.
yippeekayay
Hi I am about to do this conversion myself..... how do you rate it, has it been relatively easy or a nightmare...I have a l reg with a snapped cambelt engine that been out of the car for 3 years.... any more pointers would be gratefully received...
nickaliath
Yeah go for it !!! the only thing i found a bit taxing is the wiring!! Other than that its not too bad really.
Main things about conversion i found are:
  • exhaust manifold fitting (needs to be cut and rewelded)
  • Wiring loom
  • Brake servo clearances to cam cover
  • clutch type (i used a mi-16 clutch with 1.9 gti gearbox)
  • accelerator cable (some use gti-6 or universal type)
Edited by nickaliath
nickaliath
Been working on tidying the inlet manifold up today.
The only thing left to do is electroplate the bolts and its all ready for the end refit :ph34r:
SurGie
Very nice :ph34r:
Is the inlet manifold easy enough to take off, ie few bolts off then pull ?
nickaliath
yeah its not too bad.
once you have the wiring out the way then its about 10 bolts to remove.
nickaliath
Attempted to paint my roof today out under my gazebo!!!!
Not a good idea with the wind and rain!!!
I needed to do it though as the aftermarket sunroof has been leaking for ages and im fed up with sheeting the roof up all the time!!!
Anyway rushed through all the satages got the lacquer done, which all looked ok............ Then the wind picked up blew the sheeting onto the lacquer!!!!!!!!
Oh well, gives me more of an excuse to get the carport built!!!!!!!!
bring on summer
nickaliath
to add insult to injury looked out the window this mourning and a birds has poo'd on the roof!!!!!!!!!!!!!
