1 FAT PUG
Fuel Pump Relay
1 FAT PUG
cant seem to get any power to the fuel pump, so thought i would try this, where abouts is it located on 205 1.9 gti 1992 ..??? sorry its in wrong section but i got to get my car moved asap thanks :o
johno_78
cant seem to get any power to the fuel pump, so thought i would try this, where abouts is it located on 205 1.9 gti 1992 ..??? sorry its in wrong section but i got to get my car moved asap thanks B)
It's buried near the ECU under the steering wheel. Give it a tap to see if it's sticking when you turn the ignition on.
check the fuse too, Fuse 14 IIRC, closest one to the driver.
1 FAT PUG
sorted it out, wasnt checking it properly, and so turns out it was the pump, £42 + vat from gsf n jobs a good`n :-)
