chris-stdt
Best Way To Take Up Slack In Th L Bracket
chris-stdt
The gearchange on my car is crap ,i was going to buy a new set of rods but when i jacked up the car the long rod has been replaced and the others dont seem bad.
Most of the play seems to be coming from the L bracket ,i see bbm do a brass bush set to go with the rods they do but it costs £25 so i am looking for suggestions on how to achieve the same effect on the cheap ;)
Any suggestions welcome
Chris
Galifrey
Make your own bush
buy the bush set and also add more weld to the sleeve to prevent it coming loose in the L shaped plate.
or modify a 306/xsara/belingo/partner bush to fit.
Edited by welshpug
chris-stdt
Which part of the sleeve do you suggest adding weld to and why ?
Just buy the standard plastic bushes, these do not cost much.
+1, they make a big difference!
