Fazza6868
Tappy Tappetts Is An Oil Change The Cure ?
Fazza6868
I have developed a tappetty sound only really under load or at mid to higher revs on my Mi16 . I am going to do an oil change tommorrow and plan to replace oil with top quality stuff and obviously a new filter. Hopefully from reading through hundreds of threads this may help If I have a lazy tappet
Should I use a flush first ?
what oil is preffered I was going to get the Fuchs 10-40 semi synth
Edited by Fazza6868
Pob
What engine is it?
Dan
Fazza6868
Ooops sorry Mi16
Cameron
Try a genuine Peugeot oil filter when you do your oil change, lots of people on here recommend it!
Fazza6868
Thanks cameron I will do , what oil is best though and should I flush it?
Cameron
Any decent quality oil, you don't need to go for the best of the best. I normally run Mobil 1 in mine but decided to go for Millers in this build and so far its been pretty decent, I haven't noticed any difference and its quite a bit cheaper so I'll be using it again.
Fazza6868
I have just bought some Wynns Hydraulic valve lifter treatment, has anybody had any experience with this stuff ?
KRISKARRERA
Same problem with mine. Tried umpteen regular oil changes and a flush. No difference. Convinced the tappety noise is thanks to the cambelt snapping 5 years ago.
