KieranGTI
Selecting Gears
KieranGTI
My 205 has been stood idle for a good while, as you try to select gear i will not go in to gear.
It currently grinds, the clutch is fine, would it be the clutch cable its self if so there are two
Type's mine being a phase two. One is longer than the other which do i need the longer or
The shorter.
sam jfm
Does the clutch disengage? if it does i cant see the cable being the issue?
Need a bit more info; So the engine runs, you have a clutch pedal, ie. it's not on the floor, but when you depress the clutch and try and engage a gear it crunches?
Edited by Baz
Lan
have you tryed adjusting the clutch cable?
EdCherry
Clutch arm bending/broken.
KieranGTI
Just like that, i tried adjusting the cable don't know if im doing it right. But still no luck
Galifrey
If it has been standing a while, it is possible the clutch is sticking to the flywheel or pressure plate.
Try putting it in gear (engine stopped) foot on clutch, and then try starting it, see if the car moves.
miamichris
Check the ball joint on the subframe is'nt loose, as I had this on my xs before and it was hard to select gears. Other than that, it could be the clutch cable needing adjusting :(
KieranGTI
Yes the car will move when i try to do this.
KieranGTI
Any idea's on how i could release it.
Galifrey
get some mates round, stick it in gear, foot on the clutch, rock it backwards and forwards.
