A2TheA
Fuel Injector Order Mi16
A2TheA
does any one know how to tell which injector plug is which.
mi16 1.9
is there an easy way of telling which is which?
Aaron
richsmells
I'm sure on motronic they batch fire.
Edited by richsmells
A2TheA
yeah that did pass my mind :)
DamirGTI
Doesn't matter , you can mix up the order of the injectors and injector plugs on both the Motronic and Jetronic system as well ...
Damir :)
A2TheA
thanks damir
treesimon
Damir :)
I know that the order of the plugs fitted to the injectors doesnt matter as they bulk fire but why is this? Surely it must be a waste of fuel on the cylinders that arent firing?
DrSarty
Because the valve(s) is/are not open to let it in, so a fraction of a second later it goes in when the valve opens. Not wasted matey.
Ryan
The fuel vapour hangs around in the inlet until the next time that particular cylinder fires. Even at idle it's a fraction of a second at most, and at higher rpms makes no difference.
Firing the injectors separately has virtually no effect on power or economy. It's common on more modern cars, but mainly only for emissions reasons.
treesimon
Thanks that does make sense.
