KieranGTI
Alloy Wheels
KieranGTI
I have got a set Oz super T's originally of an xr2i fiesta. I have tried to fit them to the rear of the car but will need spacers and longer wheel studs.
Will these wheels fit any how, what size spacers should i need, also i have locking nuts on the car but no locking nut key, i got the two back nuts off
But cant shift the two front. Would this be a peugeot locking nut or aftermarket, how and where would i get hold of a key or get them bloody off.
A2TheA
go to your local garage and they may be able to help you. are they studs or nuts? if they are studs you will need to drill them out and re tap the thread.
also you have posted this topic in the wrong place. i moderator will most probably move it or delete this one.
Aaron
boombang
I bought a kit from Halfords supplied by OZ which included hubcentric spacers and longer bolts. Was a pain to get them to order in, but was very cheap all things considered (£60 IIRC).
Afraid I can't help any more than that, but worth looking through the OZ site to see if they still do them. Was for Superleggeras so check bore size.
KieranGTI
Thanks for the reply
