jaggers12
Ignition Coil Wiring
DamirGTI
But do note that the actual colour of the wires may or may not be identical , as they're a bit different from one to another year model (this pictures above are taken from a Ph1 1.6 car ..) .. so you'll need to check the wire numbers as that is the only precise wire identification (for this , you'll need wiring diagram , so , download Haynes book here please : http://www.205gti.com/downloads.htm) the wire No. is stamped with black letter/number markings at the each end of the wire near the end i.e. the connector or similar ..
Damir :lol:
P_Monty
Thanks for that. Just need to get home during daylight hours now :-)
ALEX
What exactly does the shielding wire (number 3) do on the plug for the ignition amplifier?
Mines been ripped out (rements of a connector inside) , do I need to connect it to something?
(i.e the coil shown on pic one)
Edited by ALEX
