satpink
Who Sells Inlet Manifolds For S16 & Blackbird Carbs
satpink
i have bought some blackbird bike carbs & need an inlet manifold i have seen the bogg bros website but there arnt any prices listed, does anyone on here fabricate them or know someone who makes them thanks steve
unariciflocos
Get a std injection manifold and do this:
http://forum.205gtidrivers.com/index.php?a...ost&id=7247
Then fabricate longer connection pipes for the float bowls and extend the linkages between the carbs to space them out to the same distance as the inlet manifold. Then attach the carbs to the manifold with rubber hoses. Mine were a perfect match having the same diameter. I think this solution is better for flow having no bends or unequal shapes and lengths.
ORB
I made my own a while back, I then bought one from Shenpar. Google it :angry:
satpink
dont think i could fabricate my own would end up bodged, i do have a standard s16 inlet if ou would do it for me, will pay no problem thanks for replies
danpug
Colin Satchell (eeyore on here) might be able to help.
satpink
i will pm him, if anyone else has any ideas or help please post up thanks steve
ORB
Seriously, email shenpar. They sorted me out and I am sure it was this side of 200 quid.
tony perks
Bogg bros £180 send them the inlet gasket your using and the what carbs your using sorted.
ORB
Boggs make them indeed, but you wont get one this year!!
craig_007
Yep Bogg Bros done mine before I bought it,Made the manifold,stripped/cleaned the carbs,set the carbs up and I have to say it go's not to bad !!
I would give them the thumbs up anyhow.
Craig
