Guest Bluray
Throttle Bodies
Guest Bluray
Hi all,
Just joined yesterday and would like to try and get some info on bike throttle bodies. I bought a set of bodies from a GSXR 750, its missing the linkage and TPS, I saw once that someone on the forum had done this conversion. So the questions are:
Where can I find the TPS, or what will fit.
Same with the linkage.
Is it possible to run these without changing the ECU.
Any help would be great.
Edited by Bluray
Saveit
I would imagine that you could get one off a GSXR 750... But thats just a wild guess... :P
kyepan
have a good trawl through the xu engine modification section.
try the search also it takes a bit of getting used to
also you can try google using
site:http://forum.205gtidrivers.com search string
as that will search for terms less than 4 characters.
finally.. no you would need after market engine management to monitor the air flow.
suggest you read up on the standard bosch jetronic set up used on pugs to understand how it meters air and injects fuel.
Edited by kyepan
Guest Bluray
Okay guys thanks for the help. Better get searching.
pugpete1108
i think i got a spare tps that will fit these bodies actually i have two as i'm not using my bike bodies anymore
let me know if you want it?
