si_03
Fitting 1.9calipers To A Standard 1.6
si_03
i am thinking correct that the standard 1.6 calipers can be swapped directly with the 1.9 calipers and using the origanal 1.6 disks. is there anything else i need to do or not
cheers si
DrSarty
I can't answer that specific question, but...
What wheels are you using? Sometimes 1.6 pepper pot alloys don't fit over 1.9 calipers.
DamirGTI
Just 1.9 caliper bolts and that's it ;)
Damir :lol:
si_03
cheers for that were abouts is the best place to get the bolts from
cheer si
Peugeot?
Either that or from here, i probably have a spare set kicking about!
Just 1.9 caliper bolts and that's it :)
Damir B)
Not forgetting the 1.9 brake pads.
DamirGTI
Damir :)
And the carriers...
:rolleyes:
John_B
I'm thinking of this myself having more than likely just knackered one of my 1.6 calipers.
So you just get the 1.9 calipers, carriers and bolts and your set? It doesn't matter if your 1.6 had Bendix Girling whatever?
Is there only one type of 1.9 caliper?
What about the different disc offsets? That doesn't affect anything??
Oh yeah, I have the 1.6 Goodridge braided hoses. Are they the same as the 1.9 set at the front?
billybluesky
As the thread says 1.9 calipers complete with pads carriers and bolts. I fitted them on my 1.6 c/w 1.6 goodrich hoses and 14" pepperpots no problems, got the bolts off a 306 i think from the scrappys
unariciflocos
Imho it's easier to change the disks rather than the carriers.
Get 1.9 calipers, bolts and disks.
shalmaneser
ARGH NOOOOOO!!!!!
This is totally wrong.
To upgrade to 1.9 brakes on a 1.6 gti you need...
1.9 calipers (and pads :) ), 1.9 bolts and you retain the standard sized 1.6 discs.
This has been discussed many times, maybe we need a sticky??
Your braided hoses will be fine for either 1.6 or 1.9 calipers.
Edited by shalmaneser
Yes you retain the 1.6 discs, otherwise they'll be the wrong offset for the calipers, as you're still running the 1.6 hubs, whih determines where the calipers sit over the disc!
unariciflocos
Ah, sorry for the confusion. The previous owner of my car had 1.9 disks with 1.6 calipers and i remember i couldn't fit new pads because of the wrong offset. Then I got 1.9 calipers and 1.6 disks for the 1.6 hubs.
Sorry again for the confusion.
smokey
Just to add to this thread becuase i've been doing the same conversion.
Although i decided to use 1.9 disks and got 1.9 hubs to do that.
The question i've got is did the 1.6 have brake sensor wires?
Its just my 1.9 pads have the sensor wire but i don't remember unplugging my old 1.6 brakes from any wires.
This is on a CTI btw
