Andy F
Mi Crank Sensor
Andy F
Hi Guys
I am just sorting out the various sensors to go with my emerald management.
When i built my engine it didnt come with a crank sensor. I wondered if anyone had a picture of what the bracket looks like bolted on as i will either try and find one or if basic make one up.
Thanks for the help
Andy
they don't use a bracket, its just bolted directly to the top of the bellhousing :(
they are a common part, you don't have to have one specifically from an Mi16, even the later diesels use them.
Mad Professor
Here is a picture of mine.
As said don't bother with brakets ect, it's not worth the hassle.
Edited by Mad Professor
[L'e$kro]
... Unless you don't have hole to fit the sensor, like on my early Be1 :(
Nicolas
Andy F
ahh excellent, nice and easy, ill pop down the scrappy should be easy enough to find.
Thanks for the help
if its the original box from the car in your sig, or the Mi16 box it will have the hole ready for the Sensor.
sub205
... Unless you don't have hole to fit the sensor, like on my early Be1 :ph34r:
Nicolas
when this hole would be longer, you could change ignition timing just by repositioning the vr-sensor. ;-)
Edited by sub205
