hcmini1989
Fuel Pump Wiring
hcmini1989
right i need to do the wiring for my fuel pump and my megasquirt. problem is im being a lazy sod and want to use the wiring thats already going to the pump so ive pulled my back seat up and there are 5 wires going through the floor and i just need to know wich ones are live and wich is earth.theres 2 thick ones a white one and a green one so are theses the pump ones .and the other 3 small ones for the sender in the tank thanks for any help
Wouldn't it be easier to find the fuel pump wiring by the tachymetric relay?
It should be the thick white wire iirc, green is the earth but these two ought to be in a two pin plug that only fits into the fuel pump.
pugpete1108
aren't these oposite using megasuirt?
pug use a switched earth iirc and megasquirt using a new pump relay switches the live instead
on mine i have given it a direct earth (thick yellow green wire) and run the live to the relay (blue wire)
check them using a direct live and earth to the battery or other 12v source you will hear it whine when it works
megasquirt only switches to earth not live, unless you plan on using the relay to switch the earth and running a permanent live to the pump which is not advisable unless fused obviously.
or are you using the original relay and using the ms to operate it?
Edited by pugpete1108
hcmini1989
ive tried finding the relay for the pump but it has a mi engine in and the wiring loom is a complete mess there`s relays all over the shop .so just easier to take the wires going from the pump then ill cut all the old loom out when im finished thanks for the help
hcmini1989
its ok just needed to know wich wire does what
the wire for the fuel pump will still be in one of the 2 brown plugs under the dash next to the steering column even if its an Mi16 loom with the two relays or the gti loom with its tachymetric relay.
Edited by welshpug
kyepan
what he said.
Wire 76(possibly 76a) goes from one of the relays probably found in the engine bay(mine are in a box together by the drivers headlight, you should have two together) to the fuel pump (via the fuse board).
paulsupervts84
would it not be easyer to get a conversion loom what just plugs straight in
hcmini1989
iye probably would .but nobody seems to make one for megasquirt and it is cheaper to do it this way on a bit of a budget
Edited by hcmini1989
Richie-Van-GTi
If all else fails and the wiring is totally bodged pick it up at the fuseboard and run an inline fuse and a new relay wired for the MS setup. Thats how I done mine to eliminate any future faults. If your making a new wiring loom with MS then simplify everything else first. makes future jobs 10 times easier.
I originally made a small fuseboard for all the engine and fueling under the steering wheel so it was completley seperate from the chassis wiring other than the ignition switch. All fault finding after that was a piece of P.
