sub205
Ms2 Trigger Settings For Xu-engine?
sub205
can someone tell me the right trigger settings for the xu-engines with an ms2 cpu?
currently i got the following, dont know whether its right.
I think the trigger angle of tooth 1 before TDC is closer to 117 degrees, but I'm sure Sandy can confirm that.
Mad Professor
If you are using the sensor in the top of the gearbox then you want "Tooth #1 Angle (deg BTDC): 114".
All of the other settings you have there should get you going.
sub205
thanks a lot.
