pugpaul
Power Lead
pugpaul
Where in the bulkhead do I put a power cable through to feed my amp?
DrSarty
Try behind the glovebox where there's a grommet you can use.
Ensure you do use a proper rubber grommet to protect the cable from 'chafing' against the metal edge of the hole. This would be bad; car fires start this way.
