timb1046
Converting A Pas Rack?
timb1046
i have a PAS rack in my 1.9 however when i converted it and put the MI in i damaged some of the pipes and so just cut them off in the end. so can i just cut the pipes right down and then use it as a non PAS rack? do i need to blank anywhere off?
Regards
Tim
madspikes
I'm using my PAS rack as non PAS, and its been through a couple of MOTs like it.
All I did was remove all the pipes and ram, then blocked up where holes where pipes went into the rack.
Mad.
timb1046
cheers for that. i'll give it a go tonight. did you do it with rack in situ or take it off?
Tim
It's a bit fiddly whilst on the car, but it can be done.
timb1046
great, that what i want to hear, not the fidly bit as i seem to have big clumsy bear hands. but the in-situ bit
Cameron
Its not too hard to remove it though, will probably be a lot easier than trying to do it in situ. Especially as the ram is at the back!
timb1046
i didnt get time to look at it last night, i'll have a look tonight maybe if i can make some time. cheers for your help, i'll keep you informed on progress.
