jimistdt
Size Of 1.6 Wheel Bearing
jimistdt
Could somebody lay their hands on 1.6 wheel bearing and confirm the depth and diameter of it please.
Thank you muchly.
od 72, id 35, width 33mm.
jimistdt
Bleedin' 'ell - did you just have one to hand?
Thanks for that.
jimistdt
And do you know the OD of a 1.9? Don't suppose it's 76.5mm?
no bearing to hand, just a load of handy bookmarks on my internet browser where I can find information like that fairly quickly.
jimistdt
Thanks again WP.
Is there another bearing for the base model hub?
Does that use it's own bearing or is it the same the 1.6 above?
Sorry for all the questions but there is a point to all this :)
same bearing and hub carrier as the 1.6, just the wider offset on the 1.6 drive flange/hub dooberry.
jimistdt
Can you read technical drawings WP?
If you can will you PM your email addy and have a look at this pic? I think it's for a 1.9, but I really need to 100%.
Jimi, the drawing you emailled me is almost definately for a 1.9 hub imo, it even looks like it might have the ABS sensor hole in.
I wonder if we could find a custom bearing to fit the 1.9 hub (82mm o/d) but with the ID of the 1.6 / base model drive flange. :wacko:
Graham.
what are you aiming to do?
I know there is enough meat on a 1.9 drive flange for it to be turned down to fit a 1.6/base model bearing.
Edited by welshpug
