StuF215
Shorter V6 Alternator Belt
StuF215
Anyone know which belt I can use after removing the power steering and air con and only running the alternator? Do you other v6 boys by an off the shelf belt or add an extra tensioner in?
I have found a close match which I have got from halfords but it still sweaks like a mofo! I need a shorter one.
Stu
Goliath
I went to GSF and bought a '4pk 875' belt. It's a common belt from loads of cars apparently.
Cameron
If you get a bit of string and run it around all of the pulleys and tensioners (with them slackened a bit), add about 20mm, then go to halfords and just go through their stock of belts you'll find something. Provided they don't get pissed off with you. I had to do it for my non-standard alternator and got one that fits perfectly. :lol:
Goliath
Stu
Just gone out to check and I have a spare belt if you need one :lol:
marksorrento205
Do you have two :lol:
StuF215
I cut down the original and stapled it to the 'correct' size then went halfords but the closest I could find is the one I have, the next size down was way to small, the size up too big. Or just a different width or tooth pattern.
quote name='Goliath' date='Sep 25 2009, 06:27 PM' post='991490']
Niiice!
I'll give the pool ecp a call in the morning see if they have one there in stock. If not ill be gald to take it off your hands mate yup!!!! :lol:
StuF215
Sorted one today works a treat, no sweaks!
Wont be needing yours goliath, Mark its all yours son :P
