weejimmy
205 Turbo D Brake Options
weejimmy
for my gf's car she wants to uprate the brakes as they cook somtimes.
its a d turbo and has the proper gti style wishbones etc.
will it have 1.6 hubs? or basic hubs?
it somes with solid discs at the front with basicly a 1.6gti caliper with the shorter yoke for the solid disc.
can i just put the wider 1.6 yoke on with 1.6 vented discs? as i have a few 1.6 calipers lying around.
ive read about using the 1.6 caliper with the 1.9 disc on here. is this for base modle hubs? and there fore if it (the d turbo) has base modle hubs will i need 1.9 discs?
dont wana go down 266mm road as i have everything else here and her calpiers are nearly new.
basicly i think i need to know what hubs i have and how do i check?
thanks
edit: oh and whats the difrence between 1.6 and 1.9 disc?
Edited by weejimmy
weejimmy
cool so i need to go with the 1.9 discs and 1.6 calipers + yokes then i think.
was hoping youd see this jimi
Edited by weejimmy
jimistdt
Thats what I had on mine til I swapped over to 1.6 hubs and struts. :)
Lan
aye 1.9 discs and 1.6 calipers jim, there is no yoke for the bendix calipers they should just bolt straight on :)
weejimmy
well its not a sliding yoke its just the bit that holds the pads. not sure what its called but it can be unbolted from the caliper and changed for the wider ones i have to acept vented discs, i could just swap them over but the calipers on her car are nearly new, so want to keep them.
dose anyone know the difrence in size between 1.6 & 1.9 discs or are they just difrent offsets?
just different offset, and its the Pad Carrier you need to swap :blush:
weejimmy
pad carrier yeh that sounds right. i just looked on buypartsbuy and it tells you the sizes both 247 mm by 20.5mm
and 1.9 are cheaper woo hoo score
