bizket205dimma
1.9 Gti Brakes
bizket205dimma
hi having problams just changed my master cylinder and
found that the bleed nipples have been snaped off is this common?
can it be fixed. or has any one got a set of rear calipers?
thanks in advance
Yes, it's common for the rear bleed nipples to snap. They can be drilled out and retapped, but you need to be careful not to drill off-center or down too far damaging the seat that the nipple seals against.
I have a pair of rear calipers with free-moving bleed nipples and sliders if you get stuck - drop me a PM if you're interested.
