Pob
Electric Window Problem
Pob
Hi all,
The passenger side window has always been a little slow but recently it's been playing up. Now it won't go up, only down. When you press down it doesn't stop straight away, it slowly stops.
Could this be a wiring problem or is the motor nackard? Also the central locking motor has stopped working on the passenger side aswell which made me think it's electrical
Thanks,
Dan
rapidcossie
probably a dodgy window seal causing it to go slow.
the central locking motors always go, its prob just a coincidence
davev
its also worth checking your switches.
i say this as my passenger one is doing similar, but it works fine off the drivers switch.
i also had to clean the drivers switch when i first got it and their fairly simple switches that had quite alot of corrosion in.
omri617
Hi all,
Thanks,
Dan
Sorry for brining this up , though i prefer this than opening a new thread :
In my GTI , the window of the the passenger is going up very slow only when i try to operate it from the drivers side
when i press on it's side it goes up really good.
when i lock the car with the central lock it goes to the middle and stops
tried to change switch and didn't work
any ideas? thanks
